Lowndex
Post Marauder Mod Disorder
You need to disconnect the vacuum line and set your static pressure on the regulator with the car running. Set it to around 48 psi as a starting point. Once your good, re connect the vacuum line and verify it reads 39-40 PSI.
Once you add boost, add 1 PSI for every pound of boost to 40 (approximate) as your new static target number.
Thank you.
