Re-tune ???
paheff
Member
I originally sent this to DR as a PM, but the more I thought about it, I realized that there may be others with similar questions or some input so ..........
Dennis, you flashed my car about 2.5 to 3 years ago along with 4.10s plugs etc. Since then you have done the "Cobra" exhaust. I have a JLT RAI on order and will most likely swap mufflers for Flo-Pro (unless there is a good reason not to) next week. My question is this, would I benefit from a dyno tune, and if so, should I get the hand-held tuner so that as I continue to modify, piece at a time, I can get the appropriate updates to install myself?
A dyno tune would be ideal, and yes I would invest in a Xcal 2
Dyno Tune...
I also need a "Dyno Tune", hopefully when ever Jerry W. is available to do it......Thanks...:coolman:
