rear shocks??
LUCKY GENE
Junior Member
My 2003 with 65k is need of rear shocks. Any suggestions on what brand to purchase?
drive safe
:thanks::thanks:
I just ordered OEM Motorcraft shocks today. From what I have read here, you cant go wrong with stock . Rockauto was the cheapest I found...$140 shipped for both.
OEM's are best, however I did some work on Krytin's car yesterday and he has the KYB gas adjust and they handled the bumps extremely well on my road test although they are a bit more "sporty" vs the OEM's.
True Dat!
The KYB's are as Tom says - a little more sporty than OEM and the ride is better than it has been since I first installed the QA-1's (the used ones I took off are available for anyone foolish enough to try them - they are in need of major overhaul).
Thanks again Tom
I am the second owner of a 2003A MM. I would like to purchase OEM Motorcraft rear shocks on line, but need to know my production date. Thanks!:)
Production date should be on your door sticker.... but as mentioned, it should not make a difference. I have first-hand knowledge that there are only two OE service shocks for the '03-04 Marauder:
Front 7W3Z-18124-H (ASH1153) and Rear 7W3Z-18125-H (ASH1152) :beer:
Read my signature regarding what is needed for the stock replacement rear shocks.
Also, PM me your VIN if you want the build date of your MM.
