Good note / Mine sounds better [more rumble at idle - Mid range pulls harder and 1/2 to 3/4 mile per gallon gain and this is with a D.R. Tune :beer:As long as it goes faster and sounds better, who cares about mileage?
I use Jedi mind force to channel my exhaust.
MISINFORMATION PEOPLE!
Goodness, people have only been doing this for years, I would've thought it'd be understood now.
Your REAR catalytic converters have no efficiency monitors on them, so removing them makes no difference to the computer, it will never know the difference, you WILL NOT throw a code.
The exhaust chain in regards to emissions control flows like this:
Manifold -> 02 sensor (for A/F monitoring) -> primary catalyst (smaller set) on the down pipe -> 02sensor (for catalyst efficiency monitoring) -> secondary catalyst (larger set) -> rest of exhaust.
You should most definitely notice a volume increase unless you just have super quiet mufflers, in which case you may consider going that route first.
Incorrect.Your check engine light will come on
If what you say is true, then you can now remove the front cats too, but probably wouldn't sound the best using stock manifolds.If you are talking to me, there is no visual inspection here.
My rear sensors are turned off, rear cat deleted, no light, and I passed the OBDII inspection with no problem. The front sensors are before the first cats, so how would the car know if the cats are gone? I'm golden.
If you're referring to airjordan, mrblugrv is correct.
Stop being a Nancy and DO IT!!! What's the worst that can happen? You fail your inspection and get them put back on for $50. Easy...Im getting confused here.. WILL I BE OK IF I DO THIS?? Cause i went yesterday and after the guy told all that i asked my question on here to get a correct answer.. If its fine ima go ahead and do this today.
OK, I stand corrected about the rear cat delete and no CEL associated with it.
But that still leaves the logic question. Tunes usually have the rear cat logic turned off. Wouldn't that give a "not ready" code for that parameter?
I took my car into the dealership for a diagnosis on a unrelated problem and they informed me I needed two CAT assemblies. I didn't get them but they sent me to an exhaust shop (sub contractor) to have the system tested using some sort of pressure tester and drilling a small hole in the exhaust pipe. System checked OK, later I thought maybe it was because my CAT logic was turned off.
My point being, something in the OBDII test keyed the technician that the CAT system was faulty. Would the OP's car also fail this test if logic was turned off?
Don't mean to be picky but it may help to get answers before he commits to alterations of his emissions components.
The fine for this is tremendous. Go to any muffler shop and the warning signs are clearly posted.
For those of us in non-emissions testing states, no big deal. What happens when you sell the car and the new buyer gets tagged.
Sorry for being a pain in the arse.
I'll remove them when I get the Stainless Works headers. Until then, my car has a perfect exhaust system, in my oh so humble opinion!:burnout:
HmmM... I shall wait and see what happens!
