Replacement tires?
  • Thread starter Thread starter kanukong
  • Start date Start date
My local tireshop has/had 3 used sets with about 3k miles available ........well actually 2 sets left after i left . I paid 330 installed an balanced for oem bfgs. I can get new oems for $730 including tax if ordered through my job an are instock frt or rr. I started a thread in the FOR SALE section so if anyone needs oem tires pm me. :burnout:
So 255/55/18 in the Rear?
This sounds good since the BFG stock rears of 245/55/18 are so rare.
Just tell me 2 things all you MM gurus:
Does the 255/55/18 in the rear fix the center wear problem we have all been experiencing?
And if it does, what PSI is optimal to prevent it?
Thanks
I just ordered two new Goodyear ResponsEdge tires for the rear this afternoon. They say I should have them tomorrow.
UPDATE: Just talked to Tire Rack about my order this morning (10/23/07). They said they just got word today that BFG rears should be shipping to them again within 3 weeks. I decided to amend my order and go with the OEM rears. Arrived on my doorstep on 10/31 - had to get them in the garage before the trick-or-treaters started coming! Now, they are stinking up my garage since the rubber is, apparently, quite fresh. Don't know when I'll get them on yet.
This is why I bought 4 255/55-18 kdw2 tires from Wes, front I'll worry about whenever their needed since their a normal size.
I got the Nitto 420s 255/55-18 in the rear with the stock in the front. No problems, and I have a traction control equipped model.
What about sticking to one brand/style all around?
It's long been "common knowledge", or at least common tire dealer advice, to ALWAYS put the same brand/style/model tire on all 4 wheels, and performance cars may vary from that only in running larger rears (but still same brand/style/model).
Is this advice really true or useful?
Are any of the posters here experiencing ANY performance or handling (especially emergency or extreme handling) degradation WHATSOEVER by mixing brands; like running OEM BFG's up front and some other brand/style/model 255/55x18's on the rear?
Adhering to the "same brand/style/model" rule obviously limits choices, since many of the alternative rear tire 255's mentioned in this thread are not available in the OEM front tire size.
Consider....Yokohama ADVAN-ST, matched set, OE size front, 255/55/18 rear, UTOG rating 320/AA/A, hi-perf suv tire for Acura, BMW, Benz, Porsche, Range Rover..should get superior wear over the bfg
Thanks
My center wear issues were caused by my right foot... :cool:
I am also running the 255-50-18 KDW2's I got from wes (they were new for MVV)... and I am trying to keep the burn-outs to a minimum since they are no longer made...
:burn:
I was on Tirerack.com a short while ago (this morning) looking up their price for stock fronts (I'm getting to be in dire need of at least one new front). I found that they now have the 245/55 stock fronts back in stock. Click here for the page.
I was on Tirerack.com a short while ago (this morning) looking up their price for stock fronts (I'm getting to be in dire need of at least one new front). I found that they now have the 245/55 stock rears back in stock. Click here for the page.
(ignore previous post. made an error with editing it and created a second post on accident)
