Wanted To Buy Side Moldings
Hummer_03
Hey guys, I just painted my Trilogy Marauder and I'm in need of some new side moldings. Where is the best place to purchase theese? I know they are discounted but someone has a source. Help me out if you can. Thanks
You need all (6)? I have some but not sure if I have a full set but I can check.
Both of my Drivers side door molding are reusable. I need both front fenders and both Passenger side door moldings. I looked on ebay but I was unsuccessful finding everything I needed. Your help is appreciated.
I will check for You!
Yes, I have all (4) that You need. Message Me Your email or phone #.
They are obsolete and no longer available. Even reproductions are obsolete. I spent weeks scrounging on ebay, carparts.com, emails and phone calls to dealers before finally rounding up a full set to save for the day mine need replaced.
GM is different. CV had 3 different types, so make sure you're getting the right parts. One of them is the same as the Marauder.
Which one?
CV Sport has the correct ones, but there are others. Maybe even Grand Marquis LSE, but it is even more rare than the Marauder or CV Sport.
Part numbers off of my packages are listed below. Some of the numbers are superseded by a newer number, and some of these are newer numbers that superseded the old number. Find all of the versions and search, sometimes you find somebody listing the old part number for sale. Also, if you can find aftermarket/reproduction parts lists and cross reference, sometimes you can search by the reproduction part's manufacturer part number instead of the Ford part number.
Fenders:
(R) 5w7z 16036
(L) 5w7z 16037
Rear Doors:
(R) 5w7z 5425556
(L) 5w7z 5425557
Front Doors:
(R) 5w7z 5420879
(L) f8az 5420878
Sometimes you can just switch the first 4 characters and find the same part with different number versions, for example f8az, 5w7z, yw7z.
Make sure it is the 3-1/4" without bright insert.
Fenders:
(R) 5w7z 16036
(L) 5w7z 16037
Rear Doors:
(R) 5w7z 5425556
(L) 5w7z 5425557
Front Doors:
(R) 5w7z 5420879
(L) f8az 5420878
Thanks for the info...appreciate it!
