Zacks Marauder
Does any persons know if the aero turbine 3030xl mufflers will fit the complete system for the marauder?
If the length, inlet & outlet diameter are the same and positioned correctly they will work.
Have you even looked under the car?
I suggest you do some research.
Not too many here like the SW exhaust , the headers yes, exhaust no due to poor fitment
Aaahh i see so custom is pretty much the way to go?
U think universal piping is a good way to go because i dont live anywhere near a mandrel bending exhaust shop
Have you tried Al Richard & Son Custom Muffler? Sounds like they could do it.
301 E Main St
Wauchula, FL 33873
Phone: 863-773-3121
aeros are loud as ****
This username is messing with my head.
At least with the XL versions it wont be as loud at the normal AT3030
If you don't have a shop that can do mandrel then go with S.W.
As for the mufflers, not too much of anything out there 3" in / 2 1/2" out with out an adapter.
That muffler is 26" long, if I remember reading correctly 25 inches was the longest people went and even then it was a tight fit....
http://mercurymarauder.net/forums/showthread.php?t=94708
see posts 4 & 9
