STOGIE BEAR
New England Marauder Member
Thank you for the difference between the A and B codes. richard crowson
Regarding the Canadian models that remained there...Is there any major differences between them aside from the Traction Control and of course the Speedo being in Kilometers as well as the ODO?
Also is it worth swapping the gauge cluster to the US version?
Thanks fer the underwhelming response
At MV10 I believe I have found another difference in the 300A vs the 300B...While looking at my own 300A I noticed that I only have one belt diagram on my emissions label. Its part number is 3U5A-19A286-BB. It shows the Marauder diagram and that is it. Only two other cars at the show that I saw had this...any ideas????
I have a late production 300b that came with a full size spare .
So are there different stall torque convertors between the 03-04's?
If so what are the part numbers?
Ok so I guess nobody knows.
... Engine code for the '03 300A is 3G-120-AA, PN 3W1Z-8052-AA, black valve covers, single knock sensor.
Engine code for the '03 300B is 3G-120-AB, PN 3W1Z-8052-AA, ...
My production # 7649
All Marauders have oil coolers.
the HVBOM for the marauder I am looking at buying 698977 says
"LESS ENGINE OIL COOLER" ...
