Leadfoot281
What?! Me worry?
My 04 Silver Birch Marauder has a factory 10.1-1 Mechanical Compression ratio. From what I understand, supercharging this motor sounds like a bad idea. Even with intercooling, detonation will be a problem. 2 or 3 lbs of boost, maybe, but 6,7,or 8 psi sounds like a disaster waiting to happen.
Obviously, it must work or these message boards would be lit up with complaints.
So how do people get away with it? Have they lowered their comp. ratios? Do they run race gas? At 7.5psi it should be good for 50% increase in "effective displacement" as well as 50% increase in torque/horsepower since sea level air pressure is 15psi (naturally aspirated) correct? Am I really just nuttier than squirrel poop? What don't I understand? I just need more low end torque. Thanks!
