Supercharged/ Interceptor / Crown Vic Door Sills
pedalpusher
Supporting Vendor
Below is a drawing of the Crown Victoria and Interceptor door sills. The Crown Vic rear sills are not long enough to support the lettering, so they will be machined with the grooves only (the upper piece in the picture below).
If any input or suggestions let me know. Same price as the Marauder parts, which is $195 for the 8 piece set.
Here is a drawing of the "Supercharged" sills. The 4.6 ones are getting a little tight on the rear sills, but they should be doable. We can do them either way, but I personally think the "Supercharged" only lettering looks better.
i like how you are willing to do custom word choices. :up:
maybe when i think of something good ill give you a call
It depends on what it is. If it is something that more than one person might want, like "superchaged", I don't mind doing it. If you want "Joe's Marauder" or something oneoff like that I will need to charge extra to cover the time.
thats fine with me, and makes perfict sence. its more the most plases would do
I don't have a Crown Vic but what if the rears for a Crown Vic just said CROWN VIC and the fronts can spell out the whole title CROWN VICTORIA.
Just my 4.6 cts.;)
BTW, mine are on there way.
Thanks Brian.
Not for me since I am not S/C but how about:
"Marauder" on the top trim piece and "Supercharged" on the bottom piece (rather than leaving it blank).
I am pretty sure that many of our S/C members will want such a set up.
If you can make the font a tad smaller (as opposed to the "Marauder" font) on the "Supercharged" piece it will really look good.
