USN_Lifer said:Has anyone ever heard of this? I just had an alignment and new tires put on about 3 weeks ago. Now I notice different creeking sounds coming from (mostly) the front end. It's more noticeable whenever I'm backing up and have the wheel turned. Any thoughts?
Brutus said:I am very curious about this myself. My 2000 Crown Vic does this same thing just as described. Always when backing up with the wheel turned and going over a bump at the same time.
greggash said:My Car sounded like a creaky old car when pulling into the driveway.
and it progressivly got worse, till I could hear it when I hit small bumps in the road.
Well, I used silicone spray (good for rubber) and sprayed just 4 spots
where the front suspension had rubber parts with thru bolts
The squeak went away after about a mile of driving to get it worked in a bit I guess
If that is all it needs to keep theese parts quiet, I will do it at every oil change
Master said:my fellow Canadians
