Sway bar bushing-hangers welded to bushing metal wrapping.
I’ve never had to add sway bar-locks to anything I’ve owned before.
Where does someone look for/buy those? Good ones. Being in Canada, aftermarket places are tough..but I’ll still take any suggestions.
While changing my struts this weekend, one of the studs that holds the front sway bar to the frame now spins freely. It's like the weld on the stud broke. Maybe someone had the same thing happen and MacGyvered a fix like RocketMan is talking about? My sway bar is now loose on the one side and not sure how to fix it.
You could remove the bolt, part 3w1z-5e490-aa.
Just saw this post because I ran into the same problem on my 2003 Marauder. I am rebuilding the front suspension on the car and I went to replace the bushings on the front sway bar. The brackets and rubber bushing are solid all the way around the bar. There is no way to take the bushings or bracket off the sway bar without cutting it. I am replacing the front sway bar with an Adtco front sway bar. Hope this helps anybody in the future.
Anybody come up with another part # to replace the discontinued front sway bar bushing mount bracket bolt 3W1Z-SE490-AA? Found two other part numbers that look the same 6W1Z-SE490-AA AND N806729-S436?
Local hardware store. Grade 8 bolt.
No way to use a grade 8 bolt since it has no access to the mount area for the sway bar bushing mount holes in frame rail. They are not a normal hole. Made for a special clip that has a bolt attached.
