I have a set of Terry's Heavy Duty Eaton swap brackets for sale. This set of brackets has the aux idler setup. I had these brackets on my cobra for idle time only. I had to grind on the top of the main bracket to clear the cobra cross over pipe and I clearanced a spot on the bottom of the main bracket for clearance for my electric water pump. This heavy duty setup goes for around 600 bucks. I'd like to get $550 shipped for this set. I also have a gates heavy duty green belt for a 4lb lower and 2.80 or so small upper. The gates green belt has idle time only also. I also have a new ford small idler that goes on the ps side and the accs belt thats new and only had idle time. I can include the green belt and other pieces for extra money. Thanks.
Jamie R.
'01 Silver Cobra
