Gentlemen,
When backing out my '04 Marauder (100K original owner miles now), I've been hearing this thumping sound when I apply the brakes.
If I just tap the brake pedal enough to engage the brake lights, but not enough to engage the actual brakes, I hear this thumping noise as well.
The sound is similar to the thump that is made by the gigantic oil pump and reservoir at a Jiffy Lube or other Oil Change place.
It doesn't seem to be affecting my braking whatsoever, but the sound is troubling because I have no idea what it causing it?
I notice the sound mostly when I reverse out of my garage and begin to apply the brake. As I'm driving around town, I don't notice it nearly as much until I pull into a parking lot with my windows down, driving at a very slow speed and then applying the brakes.
It should be noted that the sound is considerably louder with the windows open (duh).
It should also be noted that the brake pads are good all around and don't need to be replaced for wear.
Any thoughts????
Thanks!!!
Any thoughts????
Thanks!!!
