Turning off Air Suspension dash light
MM03
Member
Hey guys,
I'm sure someone knows the answer to this...:help: I recently converted the old leaky air suspension on my 2003 Marauder to coil springs and shocks. Now after driving the car for 20-30 minutes, the "Air Suspension " light on the dash comes on. anyone know how to turn it off? :confused:
Thanks in advance!
Hi MM03
Cut the Dark Green/Light Green wire on the air ride module located behind the glovebox and insulate the ends
Regards
Dereck
Thanks, Dereck, I'll give it a try... Justright, it is an improvement over what I had before... The car was unstable and the compressor was always running because it was leaking so much air... I just bought the car so I can't compare the new coils to new air suspension.
Im hoping to convert my Marauder back to air suspension. I have no dash light on, hopefully not due to a cut wire somewhere.
Do You know if this works or are You guessing?
#1618 of 3214
You may have had the bellows in the compressor go south...so you get the backend up as much as possible then unplug the height sensor and it stays at that height. I assumed you had working knowledge of the complete system and answered accordingly.
:beatnik:
