Hello all-
I recently got ahold of a new to me 2004 Marauder with (currently) 76k on it. I've only put about 1000 miles on it since i got it. Only things I've done is new serpentine belt, tensioners/pulleys, oil and diff fluid changes. The car runs and drives great but I'm going crazy trying to decipher this noise. I've read about everything from ticking injectors to rod knock. The issue here is I'm stuck on the symptoms and can't narrow it down. I'm looking for someone that has had a similar noise/fix. For the record- the noise was there when I bought it but it was in good enough shape for me to buy it anyway.
Symptoms are:
-At WARM IDLE/ HOT IDLE- slight tapping or ticking noise coming from the Passenger/RH cylinder head/valve cover area. It's real faint/dull metallic-ey echo-ey? The second you give it some gas it goes away, and is only heard again once the engine comes to rest at idle. I cannot hear this noise at cold start or while accelerating.
-can't really hear it inside the car unless you're up against a median or a drive thru, if you stand outside with the hood closed you can hear it from the rh wheel well area or if you pop the hood.
-no check engine light
-spark plugs just checked/replaced with the NGK 4177s (noise was there before this) and all spark plugs/threads were tight though it did look like someone had replaced coil #1 before.
-sometimes it's louder than others-sometimes it's barely there but I'm extremely sensitive to weird noises so it bothers me and i listen for it constantly
-I ran 3oz of seafoam in the engine oil for maybe 20 miles as things like that in oil worry me - but the noise is still there. I then promptly changed the oil with valvoline semi syn.5w20
Worth mentioning:
-The only other issues with this car is if i let it sit for weeks, the first start up is a little chattery, but promptly goes away after a few seconds- and normal from what i've read on here.
-A very faint/slight vibration at 1500-1900RPM.
My thoughts are:
*Lash adjuster (hopeful)-but the symptoms don't make sense!- Do i really need to drop the motor for valve cover removal??
*Rod knock/wrist pin-wouldn't I hear this at all RPMs? ESPECIALLY cold starts?
*Timing chain?- but again from what I've read i would hear the noise mostly up front and it would be constant thru the RPMs
*Do these 4V have oil restrictors like the 2v? Is it possible I'm not getting enough oil to the RH head at idle? How would i find this on the 4v?
At this point , I think I'm gonna pull the valve cover off anyway and check the adjusters. What SHOULD I be looking for? Any tips/tricks?
Video link:
https://youtube.com/watch?v=rmtXaRMf-ow&feature=shares
Symptoms are:
Worth mentioning:
My thoughts are:
Video link:
