Wanted To Buy Vapor return tube
william s
HOT MERC
I need a fuel vapor return tube for my 2003a. the # is 3w3z9g271a. I have a small pin hole in mine. Ford tried to fix it but I don't know if it will stay fixed. Thanks Bill
There is a picture in the ford parts catalog but I can't send blown up picture. Its part # 9g271 for a 2003 Marauder
Try tascsparts.com they still show it , but no guarantee, they don't always update their availability and you'll get an email saying out if stock, discontinued , but worth a try. Abd better to take a pic of what you are looking for as most of us don't go by part number. Alot of parted out marauders go thru this site
I can't seem to load a picture. Tasca does not have it. Its the tube that is over the right valve cover and goes toward the back of the car. It has a small blue cap on the line. Thanks Bill.
9G271 is a an ambiguous part number, most of the vapor lines have that, it' the first part of number that must designate which model...9g271 shows up all over the place.
use photbucket for image hosting
The check engine light comes on. The dealer had a hard time finding it. It was on the bottom of the tube. They did a smoke test and found it. The dealer could not get the part so they put tape around it. Seems to be working fine now. I would still like to replace it. Thanks.
Get some of this stuff.......it's AMAZING!!:eek: It seals to itself and fuses into a solid piece over time!!:beer:
I replaced about a foot of the shield on my throttle cable.....looks like new...almost!!:bows:
I should have this, I'm parting out my marauder. I'm going Sunday to take parts off so I will message you if mine is in good condition and can take it off.
