I finally broke down and have started tackling the job of replacing the carpet in the Marauder now that it's back from Mo's. I removed the seats, center console and carpet and discovered some mold in the front of the passenger footwell. The thick lining against the firewall was soaked. There was also a sheet of paper left over from the factory build of the car that was black with mold.
I didn't notice an inordinate amount of rust, so I don't think it's been wet for a long time. I did run it through a robo wash not long after getting it back, so I'm wondering if the high pressure water found a way in. I've done the old school method of shining a high intensity flashlight all around the firewall looking for light making it through but I can't see any.
Are there common areas where these are known to leak? The firewall grommet that I used to use for emergency light installs in CVs seems in place and sealed.
