What did you do to your car today?
I repaired my EATC last night. Tonight I'm putting in a new AC condenser.
On Monday (when the part gets here) I'm replacing the drier. Then, it's a quick vacuum of the system, check for leaks, then recharge.
I swapped out my 'special occasion' mint factory floormats back to my everyday rubber ones, went to work and then for a nice long drive after!
New LCM, Motorcraft Tough MAX BXT65-850 Battery & "The Works." I'm all prepared for my vacation at the end of the month w/ my mom. :)
Replaced driver window regulator and upper ball joints. I also fixed the ever so annoying defrost only AC by rebuilding the ac controller. works like a dream
I looked for my keys to my two Marauders for three ****~ING hours!!!! And didn't find them. Total hours now 14+ and counting.
With so much time invested, wouldn't it be easier to just take your valid registration to a Ford dealer and inquire about replacement sets 1Marauder? :confused:
headlight maintenance
Wet Sanded and polished my headlights, rather than buy new ones. Didn't take much effort, used 800,1000,2000 then 3000 grit, followed by the polish supplied in the Meguires kit using the little machine adapter and wheel in the kit. left the lghts on the car and taped off the work area.
Looks a lot better. I'm a happy camper again.
I changed the serpentine belt tonight. Tomorrow I'll change the fuel filter, put in the new wiper motor. And change the oil filter and cut it open to see if there's anything that shouldn't be in there.
You need to spray a clear coat on them now so they will stay that way.
At MV 14 we were told to use OFF on the headlight and it worked immediately
You really should just sand and clear. The yellow clear plastic that's deteriorating is like your body shedding its skin, just a little nip and tuck and it's like new again.....
Headlight Restoration Kit!
