ChiTownMaraud3r
boostin
Installed my big brake kit yesterday. Not impressed. Ordering speed bleeders.
Wanna know once you are done. ALl parts on top of desk, waiting....
Bet it wasn't the TCE kit.
Thought I'd change my BCM since it's been acting up lately. This is what I had to do:
Looks like to tensioner guides are good:
Had to remove the right side cam cover to access the BCM because I have an original DR rear cooling mod installed. Of course the hoses are in front of the BCM.
I figured I'd change the upstream O2 sensors. The swaps when OK. While under the MM I noticed that both upper control arm ball joint boots are torn. Also noticed that the right side motor mount was missing the nut. Waiting for Rock Auto to deliver the cam cover gaskets, new plugs (Autolite XP-103) and motor mount.
Will be ordering both upper and lower control arms, front shocks & misc. parts. Already have new camber bolts and sway bar end links and sway bar collars.
Pretty clean for a 92k motor.... Mobile 1 oil & filter changes every 5k since new.
Went for a roll!
Haven't really driven the Black (other than my 2 mile circuit) or washed it for a year. Pulled it out last night, washed it and dried every nook and cranny (we have hard water). I awoke, spray washed and waxed it this AM. Just took it for a quick spin, put some tire shine on, burned some serious sideways rubber!
Hope you didn't let them rotate the tires, and did they add the 6th quart of oil needed?
Tires were rotated side to side and yes, the correct amount of oil was filled so the dipstick level is in the recommended range RubberCtyRauder.![]()
what tires do you have? directional can't be rotated side to side unless dismounted and flipped . I only brought it all up as more than one has had the dealer rotate tires wrong.
OEM are asymmetrical (not directional, unidirectional are a different animal) which can not be safely moved side to side unless dismounted & flipped. They will lose wet traction as the water will fail to be channeled out causing hydroplaning very easy = ooops, you are screwed...She rides on BFG stock replacement tires, they aren't directional as far as I am aware of since there are zero directional markings on the sidewalls. If I am mistaken, kindly correct me RubberCtyRauder.
Thanks in advance! :beer:
Most of the replacement tires that most of us have changed to are directional thus why I brought it up.
