Hey guys, I just got back from a trip and my rear end seems to be doing something wierd. As I got home, my rear end started making a wierd vibration and rubbing noise everytime I made a sharp turn while accelerating. I just went out and tested it again, and it only does it when you are giving the car gas while doing a sharp turn. I found an empty parking lot to make a few sharp turns, and it goes away as soon as I release the gas pedal, only to start again as soon as i'm back on it no matter how lightly while turning. Any idea's? I had the rear differential fluid changed a bit ago to Amsoil Series 2000 75w90 like the manual explains. Since Amsoil's Series 2000 gear lube already comes with the limited slip additive, I did not add any limited slip additive since Amsoil says that it's not needed(my old Lightning didn't need it either). Right after the fluid change, I tested it by driving in tight circles, and it never had a problem till now. Any idea's?????????
