I have no idea what you're asking...
Actually, I re-read the post you quoted a couple more times and then your question made sense. I mentioned that I have to remove the rms to change the blades on my DD.
To answer your question, no. The problem is that even at full extension you can't move the arm away from the windscreen enough to rotate the blade to where it will come off...the arm hits the hood.
Got it. Yeah, that does suck.
That's what I do, but it takes a lot longer. On the MM I can change both blades in less time than it takes just to remove one arm on the DD...plus you have to worry about losing the little key.Open the hood and remove the wiper arms.
Fastblackmerc Have you ever thought of cutting the wiper arm then adjusting it and welding it back on so it would sit lower? This could be another service you provide.
No I haven't...........
If you make the arm sit lower it will sweep / clean less area.
I know this is a bit old, but info for anyone else looking at wiper blades or arms. I replaced my factory pin type arms with the hook type arms off of a 06 or 07 CV. I did this so I could use Bosch Icon wiper blades. I have had better life from the Icon blades than the other beam blades and they are not available for pin type arms. The 06 style arms appear to be identical to the factory pin arms except for the hook instead of the pin.
