musclemerc
Senior Member
N/A Horsepower Thread
I've reached out to a few member's for their input on what mod's they did to get their dyno proven number's. This is a list of the information I have compiled. Most or these combination's consist of just bolt on's but a couple of guy's went a step further and had custom parts added in.
All of the MM's are N/A
*top 5 horsepower and/or torque are highlighted in red*
TAF: 242HP/261TQ *Stock MM*
Bone stock MM 2500mi.
Breeze: 242HP/259TQ *Stock MM*
Flowmaster super 40's
Fordnut: *365HP/369TQ* *Highest -BBS-HP/TQ*
*5.3L Big Bore Stroker*
Heads: Ported/combustion chambers cleaned up/oversize valves/oversize hardened seats/hardened guides/ceramic coated chambers, valve's head's, and exhaust ports/teflon coated valve stems,cam caps,cam saddles/drilled out oil return holes/Cryo treatments/REM micro-polished followers/Comp beehive springs/Comp Extreme 258 series grind #106260, 222/224 duration, 475int/450ext lift
Bottom end: Cryo treatment & REM polishing on Kellogg forged stroker crank/Pauter cross-beam rifle-drilled billet rods/longer rods with raised wristpins/CP 9.5:1 forged pistons with ceramic & teflon coatings/teflon coated bearing inserts/cryo-REM treated cam gears and chains/billet crank trigger ring/Melling oil pump with billet gears/windage tray/main girdle/ARP rod bolts,cam bolts, main studs & head studs/60 lb injectors/CPR fuel rails/ twin Cobra fuel pumps
Denso IT20 plugs
Plasma booster ignition module
Metco CF intake tube
K&N conical filter and heat shield *MM kit*
90mm MAF
BBK 62mm TB
Steeda UDP's *crank pully only*
Electric WP
180* T stat
PHP 3/8" intake spacer
Ported & Polished U/L intake's *TB matched*
EGR flow restrictor
FRPP 4:10's
PI 2800 stall
Reinhart/ Art Carr transmission kit
Kook's LT's
Bassani 2.5" X pipe
Magnaflow high flow cat's
Edelbrock RPM muffler's
Custom dyno tune
Joe Walsh: *325HP/340TQ* *Highest-BB-HP/Torque*
*Forged 5.0 big bore*
Crower cams
Crower springs
+1mm Stainless valves
extrude honed intake *TB matched*
K&N 9" conical filter
Custom cold air box
C&L 80mm MAF
Accufab 60mm TB
Meziere electric WP
Steeda UDP *crank pully only*
Kook's LT's
Kook's 2.5" X pipe
Magnaflow muffler's
Art Carr high stall TC
Level 10 shift kit
B&M trans cooler w/electric fan
Custom dyno tune
dohc324ci: *317HP/357TQ*
*Big Bore Stroker -MMR Street Mod 850-*
FRPP BOSS 5.0 iron block
10.5:1 cr Manley pistons
MMR 4340 rods
MMR stroker assembly with ARP head/main studs
MMR Stage 3 p&p heads
MMR stainless steel valves
FRPP GT40 cams
Comp cam springs
MMR Ported intake
PHP intake spacer
FRPP GT40 fuel pump
FRPP 39lb injectors
JLT CAI
SCT BA 3000
MMR racing oil pump
MMR Windage tray
Impalaslayer: *306HP*/295TQ *Highest HP with stock engine*
Nazty PSRI (ported short runner intake) *TB matched*
Steeda UDP's
Accufab 62mm TB
90mm MAF with 80mm stock cartridge
GMS COP connector's
NGK TR6IX plug's
EMP mechanical WP
3500 stall
Kook's LT's
Aero muffler's
FRPP 4:10's
Custom dyno tune
Fordnut: *303HP/318TQ* *Highest TQ on a stock engine*
Denso IT20 plugs
90mm MAF
BBK 62mm TB
Electric WP
180* T stat
EGR flow restrictor
FRPP 4:10's
PI 2800 stall
Kook's LT's
Bassani 2.5" X pipe
Custom dyno tune
Maryland: 302HP/*318TQ*
K&N CAI
180* T stat
1 step colder plugs
Steeda UDP's
PHP- Stage II ported and polished U/L intake's
Kook's LT's
Kook's 2.5" X pipe
Magnaflow muffler's
2.5" Axle back's
FRPP 4:10's
Custom dyno tune
Paul T. Casey: 300HP/315TQ
Steeda UDP's
90mm MAF with the stock 80mm cartridge installed
JLT CAI
180* Stat
1 step colder plugs
Custom 1" Phenolic spacer
Custom 2" TB spacer
Port & Polished U/L intake
Kook's LT's
Kook's 2.5" X pipe
Magnaflow muffler's
Custom dyno tune
kmastl: 294HP/307TQ
K&N CAI
Steeda UDP'S
Kook's LT's
J-Mod
Custom dyno tune
Blackened300A: 293HP/312TQ
Metco Carbon-Fiber Intake tube
PHP CAI
Naz PSRI (ported short runner intake) *TB matched*
Accufab 60mm TB
PHP Intake 3/8" intake spacer
Steeda UDP's
180* T-Stat
Denso IT-20 Plugs
Granatelli COP connectors
Cherry Bomb Vortex Mufflers
J-Mod Shift Kit
Stallion T/C 3000 stall
FRPP 4:10's
Custom dyno tune
Blackbeauty2: 293HP/308TQ
K&N CAI
NGK TR6 plugs
180* T stat
Steeda UDP's
Kook's LT's
2.5" X pipe
2.5" full exhaust *no cat's*
FRPP 4:10's
Custom dyno tune
2,4shofast: 292HP/284TQ
Steeda UDP's
JLT CAI
180* T stat
1 step colder plug's
Meziere electric WP
Kook's LT's
High flow cat's
Magnaflow muffler's
Custom dyno tune
TAF: 290HP/316TQ
180* T stat
1 step colder plugs
Steeda UDP's
Stock Cobra manifolds
Magnaflow 2.5" X pipe
Magnaflow muffler's
FRPP 4:10's
Custom dyno tune
Glenn: 289HP/310TQ
K&N CAI
Steeda UDP's
FRPP Shorty header's
FRPP 4:10's
Custom dyno tune
Go2GuyFL: 284HP/298TQ---2003MM
K&N CAI
Kook's LT's
Kook's 2.5" X pipe
Aero 2525 muffler's
Reinhart tune
Crouse: 283HP/295TQ
JLT Cold Air Intake
Granatelli COP Connectors
Steeda UDP's
Stewart EMP W/P
PHP Intake Spacer
Custom 2-1/2" midpipe w/ H-Pipe
MagnaFlow 94066 Catalytic Converters
MagnaFlow 11256 Mufflers
FFRP 4:10 Gears
Custom dyno tune
ctrlraven: Zack Tune V1.0 282HP/313TQ----DR Tune277HP/309TQ
*Best-on the cheap*
JLT CAI *no heat shield*
GMS COP connector's
NGK TR6IX plug's
PI 3500 stall
Deleted rear cat's
Flowmaster super 40 muffler's
Go2GuyFL: 278HP/288TQ---2004 MM
K&N CAI
Kook's LT's
Kook's 2.5" X pipe
Aero 2525 muffler's
Reinhart tune
4drcbra: 274HP/302TQ
Anderson 4" CAI
Custom 2.5" mid pipe
Deleted rear cat's
Magnaflow muffler's
Custom dyno tune
Anonymous Member:
464HP/425TQ
*Dyno link*
Ported & polished head's W/intake & exhaust gasket's "matched" (work done on a color die flow bench)
FRPP cam's
FRPP valves
FRPP guide's
FRPP springs
Ported/polished/force blasted U&L intake
Water injected intake system w/3 nozzle's
60lb injector's
Dual GT fuel pump's
90mm MAF
K&N CAI
SW LT's
SW high flow cat's
Custom dyno tune
Denso IT20 plugs
90mm MAF
BBK 62mm TB
Electric WP
180* T stat
EGR flow restrictor
FRPP 4:10's
PI 2800 stall
Kook's LT's
Bassani 2.5" X pipe
Custom dyno tune
Crower cams
Crower springs
Custom cold air box
C&L 80mm MAF
Accufab 60mm TB
Meziere electric WP
Kook's LT's
Kook's 2.5" X pipe
Magnaflow muffler's
Level 10 shift kit
Custom dyno tune
MMR 4340 rods
FRPP GT40 cams
Comp cam springs
MMR Ported intake
PHP intake spacer
FRPP GT40 fuel pump
FRPP 39lb injectors
JLT CAI
SCT BA 3000
MMR racing oil pump
MMR Windage tray
Steeda UDP's
Accufab 62mm TB
GMS COP connector's
NGK TR6IX plug's
EMP mechanical WP
3500 stall
Kook's LT's
Aero muffler's
FRPP 4:10's
Custom dyno tune
Denso IT20 plugs
90mm MAF
BBK 62mm TB
Electric WP
180* T stat
EGR flow restrictor
FRPP 4:10's
PI 2800 stall
Kook's LT's
Bassani 2.5" X pipe
Custom dyno tune
K&N CAI
180* T stat
1 step colder plugs
Steeda UDP's
Kook's LT's
Kook's 2.5" X pipe
Magnaflow muffler's
2.5" Axle back's
FRPP 4:10's
Custom dyno tune
Steeda UDP's
JLT CAI
180* Stat
1 step colder plugs
Custom 2" TB spacer
Kook's LT's
Kook's 2.5" X pipe
Magnaflow muffler's
Custom dyno tune
kmastl: 294HP/307TQ
K&N CAI
Steeda UDP'S
Kook's LT's
J-Mod
Custom dyno tune
PHP CAI
Accufab 60mm TB
Steeda UDP's
180* T-Stat
Denso IT-20 Plugs
J-Mod Shift Kit
FRPP 4:10's
Custom dyno tune
K&N CAI
NGK TR6 plugs
180* T stat
Steeda UDP's
Kook's LT's
2.5" X pipe
FRPP 4:10's
Custom dyno tune
Steeda UDP's
JLT CAI
180* T stat
Meziere electric WP
Kook's LT's
High flow cat's
Magnaflow muffler's
Custom dyno tune
TAF: 290HP/316TQ
180* T stat
1 step colder plugs
Steeda UDP's
Magnaflow muffler's
FRPP 4:10's
Custom dyno tune
Glenn: 289HP/310TQ
K&N CAI
Steeda UDP's
FRPP 4:10's
Custom dyno tune
K&N CAI
Kook's LT's
Kook's 2.5" X pipe
Aero 2525 muffler's
Reinhart tune
Crouse: 283HP/295TQ
JLT Cold Air Intake
Steeda UDP's
Stewart EMP W/P
PHP Intake Spacer
FFRP 4:10 Gears
Custom dyno tune
*Best-on the cheap*
GMS COP connector's
NGK TR6IX plug's
PI 3500 stall
Deleted rear cat's
K&N CAI
Kook's LT's
Kook's 2.5" X pipe
Aero 2525 muffler's
Reinhart tune
Anderson 4" CAI
Deleted rear cat's
Magnaflow muffler's
Custom dyno tune
Anonymous Member:
FRPP cam's
FRPP valves
FRPP guide's
FRPP springs
60lb injector's
Dual GT fuel pump's
90mm MAF
K&N CAI
SW LT's
SW high flow cat's
Custom dyno tune
