Black Machine
Did the Sea Foam treatment on my 03 Marauder today. I went the spray can route. I pulled the plastic pcv valve tube that connects to the right side of the intake and covered the opening of the tube with duck tape. I then poked a pin hole in the end of the taped opening to lessen the amount of vac loss during the process,...I really did not want want to throw a code. I then placed the little red tube that came with the Sea Foam in the pin hole, connected the tube to the can of Sea Foam then blocked off the pcv valve opening. After starting my car I carefully sprayed about 6/8's of the can into the intake then shut the car off for 15 mins. After starting her back up, I took it out to the highway a blew her out. It smoked and ran a little stumbly for the first 3 mins while it was exhaling all of the dissolving varnish, crud and excess Sea Foam. However after it was all cleared out,...I could feel WAAAAAAAAAAY more bottom end grunt and mid range pwr. RPM recovery between shifts is alot faster and the motor just feels more crisp. Kinda like the difference in how a car pulls on a 30 degree day vs how it would pull on a 90 degree day. Air temp on the coast today was a pleasant 80. I highly recommend this procedure to all my fellow Marauder owners.:banana2:
