I did a Google search of the forum and didn't notice any threads mentioning what might be my favorite tool at work. For those that don't know, I'm a full-time ASE mechanic.
I've read a ton of threads on how important it is to properly burp the cooling system, and how difficult it can be on the MM.
http://www.tooltopia.com/uview-5500...UIUR2WUKYVoPaiv3ytDkPTGws9LN55Xk-axoCSnXw_wcB
This little guy is worth it's weight in GOLD. When you drain the cooling system for service you use this, connected to compressed air, to draw ~25 inches of vacuum on the system (via the expansion tank, on our cars). Once that point is reached, you close a ball valve and monitor the vacuum gauge. No loss of vacuum? Your system is sealed!
Fill a clean 5 gal bucket with 50/50 coolant mix and drop in the fill hose, open the valve and bam. Fresh coolant is drawn in until the system is full. It will over fill the expansion tank, I just use a turkey baster to suck it back out and bring to the proper level.
Hope this isn't old news, and a helpful hint!
