Alan - Congrats! your Marauder is CVN 'Panther Of The Month!
http://www.crownvic.net/ubbthreads/ubbthreads.php
deservedly so :bows:
Alan, very impressive! 13.7 for a car as heavy as the Marauder is from basically a stock power plant is remarkable.Well the final race of the year yielded a good time! I ended out running 13.70-13.75 all evening. MPH stayed the same at 103, however the 60' was in the 2.1's all evening, which I was happy with.
The tune was kept the same as last time, as I believe it's about as optimal as I can get it. Timing is 26 degrees and WOT lambda is .830. I am using the stock Mustang VCT cam timing still as well. Last time out, I experimented with some different VCT tables some friends were so kind as to provide, however it did not seem to change my E/T or MPH any, and all combos react different so that's probably a lot of it with me having a lower compression truck motor.
I'm pleased with the results, and so ends the N/A portion of this build. I plan to get to work around early December on the turbo setup. Going to take the time to start that swap thread and compile all the pictures and video over the next couple of months as well.
:burnout:
https://www.youtube.com/watch?v=4DfQwS7FnPc
You should be getting paid as a professional R&D tech builder and writer. Awesome, excellently written thread, and can't wait for your summary to be a sticky thread for future swaps.
This is how you do it! :beer:
I think VCT is awesome. To be able to tune for just the sound of Lopey cams is amazing.
God I miss my cams!
Builder Of Badassery
Like all 3.55 N/A Marauders....she's a dog outta the hole...
but man does she sound sweet once that Coyote is wound up!!.....:bows:
Looking forward to your sick turbo build.
You won't need a lot of gear with the turbo's awesome torque.
Has there been any news on turning the 2011-2014 PATS system off?
BRAVO. Excellent. I love the sound of the coyote vs the 4.6. Nicely done Sir.
Alan, I have another contact that claims Eric was able to remove pats from his 2012 PCM, so I expect he will be successful with yours this time. This ability is not built into HP's tuning software yet, but most likely will be added soon. It should open up a lot more applications of the 5.0L Coyote with the 6R80.
Great Job, nice results. I feel good about my time of 13.8@99 N/A with the stock MM engine. Thought you'd be lower for sure. Your MPH of 103 shows more HP than I have now for sure... The big tell will be with the turbos, and custom dyno tune. I'm guessing 11.5..
Sweet project results!
If he goes 11.5 with a Coyote and twin turbos he should burn the car to the ground
