^ Yes, and I should have been more specific on that.....sorry guys!
The C5 uses a filter that combines both a fuel filter, and regulator in 1 compact housing. It's used widely on LS swaps, and comes in handy in this instance as well fortunately!
Speedway makes a kit that includes all the fittings to mate to -AN. If you buy the filter/fittings individually, they are rather expensive in comparison to this kit. Here is what I use on all my swaps:
http://www.speedwaymotors.com/LS1-Fuel-Filter-Fuel-Regulator-Kit,41791.html
That filter will support in excess of 800 flywheel HP, and was confirmed via a reliable source via this link, during my Malibu build:
http://ls1tech.com/forums/fueling-injection/1742762-stock-corvette-99-03-fuel-filter-flow-data.html
I think a lot of times, people over think fuel systems as far as diameter of feed lines/hose go, DEPENDING on their fuel. Obviously, alcohol/E85 will require more volume.
This filter is 3/8" Feed diameter on the outlet.
My old Vic, which was easily in excess of 550 RWHP, was using the stock '97 Crown Vic fuel lines, with only a Walbro 255 in-tank in place of the stock fuel pump. The stock line diameter at the engine bay was 5/16" feed, 1/4" return.....haha.
Now, on E85, it probably would have been close to tapped out at 6-7 psi give/take.
