Indeed, I did Bob. I forgot to mention that. I took all the driveline angles prior to taking the stock 4v out. I then seated the Coyote, and re measured. It appears at this time, that the Coyote does not change any angles. At this point if I were using the 4R70W, the stock driveline could be reused no issue even with the slight adjustment rearward of the powertrain.
More to come on the crossmember once I get the 6R in there. My plans are to cut/rework and reweld the stock cross member, but we'll see once the 6R is in, and angles are set, what i'm left to work with.
Exhaust at this point will be a set of stock Mustang tubular manifolds. The truck mani's are simply too wide to work with. The passenger side would probably work, but the driver side is a no go. I took some measurements from a stock Mustang yesterday on the lift at work, and it looks like they will fit just fine. I will know as soon as they arrive for test fitting next week.
As long as the 6r tucks into the tunnel, this sukka will be a go at this point! IF for some reason it won't fit.....I will most likely use the 4R70 from here on.
Stay tuned.
