Thank you.
I believe, supplies and all was just under 2k, but i'd have to review my build sheet.
Of course that's with all labor completely free.
That makes it a $6K to $10K paint job. Very nice!
Thank you.
Here's the video demonstrating my integration with the stock '06 CAN Network Vic cluster to the Coyote ecu . Full functionality!
https://www.youtube.com/watch?v=m8pKKDKYBjk
two Coyote's, same chassis. Crazy how close we live to each other:
THIS is what I'm interested in LOL...Coyote in an 06+ Vic...did you do this swap as well?
not worry anymore boys Ford just released a control pack that is also available for a 6R680 use at PRI this weekend
http://fordperformanceracingparts.com/pri/
Nice! However, wouldn't a 6-speed auto in the context of a Marauder want to be paired with the Coyote engine and PCM as 96GT4.6 has demonstrated?
Its a stand alone computer that controls the shifts of the 6r80 so it can be swapped behind other mod motors like our 4.6 and not have to deal with grabbing a compatible PCM from another vehicle.
I'm much more interested in the 6r80 versus having a 5.0. The 6r80 in stock form has help up behind ridiculously modified 5.0's so its becoming the preferred "auto swap".
Basically the stand alone is allowing older cars to communicate with the much newer transmission.
Understood. But our cars are emissions-controlled, and a "legal" engine swap typically must keep the engine/transmission combination. Not to mention the Coyote is pretty desirable itself.
States that don't enforce emissions are becoming fewer every year.
I don't see it being an issue because you're not changing any emission related equipment. The controller will basically be the middle man between the 6r80 and the MM ECM/PCM.
That is not how The Man sees it. It sucks, but if you want a legal street car you have to play by the rules. I don't like it and don't agree, but I intend to drive my car on the street.
S/C'd with a Mo's tune passes NC inspection with flying colors w/ EGR deleted. I'll go grab my inspection sheet to see which systems they test for...
