03Merc
Active member
Has anyone measured the distance from center to the calipers back side for wheel clearance
They clear.....but, mine were modified for the weights to clear....
Things to know:
You will need to grind down the aluminum so the bracket sits correctly and the bolts thread in. Pretty self explanatory.... When you can thread the bolts in, you have ground down enough.
Also, look closely to the pic. You will need to grind a small relief where I did so the abutment bracket sits perfectly.
(My holes were enlarged for the cobra brakes on the car before this. Yours will not look this way)
Another pic of grinding:
The factory dust shield will also need to be removed for this.
What application is the rotor for?
I believe he bought the hart gt500 rotors off eBay.
Let him answer peepeehead
How much do those weigh?
You either have the wrong pads, wrong rotors or the wrong caliper bracket.
