MOTOWN
S/C 20" MINI TUBBED WHEEL GUY!
Going return fuel system is looking more and more likely. I've done a bit of reading, but I still don't understand certain things. Can you guys help me with these questions.
Thanks!
- Would I need to change fuel rails? Something about the FRPS (Fuel Rail Pressure Sensor) that I don't understand. Or is it that our fuel rails have a "dead end"?
- If I do need to change fuel rails, I read that CPR makes rails for the Marauder, but need to be modified and that they push into the injectors causing fuel leaks....
- I was thinking maybe using Cobra rails, but it sounded like these have the FRPS on the wrong side (?)
- Is it best to modify a fuel tank hat or to buy something already made for a return setup? I am considering the Walbro 400.
- Would I wire the new pump in the same manner as the old? It seems it okay to leave the FPDM (Fuel Pump Drive Module) connected b/c this gets removed in the tune.
Yes you will need new rails , i would go Fore , or Division X (they both have provisions for frps), CPR is out of business , your only option is to mod a fuel hat , no one makes one for our cars , you can't go return and leave the fpdm in place the returnless system is pulse with modulated meaning the fpdm controls the flow of the returnless system by varying the voltage to the pump.
The new pump will be wired directly to the battery via inline fuse , and relays.
