96gt4.6
Panther Swap Specialist
Excellent info on the alcohol detection technique. This is down with an ordinary O2 sensor, not wideband? Does it stumble a bit as it figures it out?
Actually, no. Starting around 2009 or so most Ford vehicles went to Wideband sensors. The Coyote uses dual wide bands. It's rather nice, the system operates in closed loop at all times. So under wide open throttle you simply put in what Lambda you want, and it targets that continually. It's also very fast to compensate and adjust!
